The list of things to do....
we all know the score - never in its 50 odd year history has anyone had a landrover that has been fault free, or needed a few odd jobs doing to get it A1 perfect.
So nows your chance to make that all important list of jobs that "you'll get round to eventually" on your landy!
then read back on the list and *#*#*#*# at your stupid vehicle.
Down pipe to be changed with a none CAT version (sat in garage)
P gasket leaking slightly
front prop sliding joint a bit loose (and UJs once a year without fail
rear stub axle has pitting on the hub seal face, needs some liquid metal skimming on or replacing to stop hub seal failure every few K miles.
rear seat needs fitting so wife and baby can both have somewhere to sit.
rear wiper motor needs replacing (never use it which is why it probably died)
front diff pinion oil seal leaking, could be a blocked breather
build a new bumper to fit around winch mount, preferably one that aint made of tinfoil like LR standard bumpers.
refit winch
replace plastic light surround on wing, after hitting a tree.
replace a wheel arch spat - see above tree (sat in garage)
thats all for now. Luckily none are major, just getting round to it thats the problem and having the odd oil spot on the drive.........
what needs doing to yours?
refit winch
Mine, seems to be growing faster than I can deal with it...
Fit new engine and gearbox
Manufacture new exhaust
Make new propshafts
Get above to run and find out what mpg it gets
Design new fuel tank to meet 500Km range needed given above mpg
Replace rear cross member with winch version
Fill hole left behind the seats where the winch sits now
Make spare wheel mount in rear tub to stand wheel up
Make new storage boxes in the back tub
Fit second shock absorbers to rear axle
Fit hydraulic bump stops to all corners
Fit 3rd battery and second alternator
Repair rear winch
Finish off navigation PC and mount in vehicle
Replace all half shafts/CVs/drive flanges/diffs with 24 spline versions
Decide on and fit new challenge tyres and wheels
Make a snorkel to suit new engine
Repaint entire vehicle with new colour scheme
Sure I forgot something, thankfully I have until October to get it all done so that's OK
Make new propshafts
Repair rear winch
davew wrote:Mine, seems to be growing faster than I can deal with it...
Make new propshafts
Repair rear winch
Well at least you'll be ok with more than 8mm of tread depth by the time you have fitted that lot!
List of things to do
I ended up missing Great Ayton trying to reduce my 'to do' list on the Series 3,
Replace all 4 springs & shocks.
Replace O/S free wheel hub
Service brakes Replace rear brake shoes.
Grease props & check oil levels all round.
Clean & Paint axles.
Replace clutch flexi hose.
As if all that wasn't enough, while I was there I found there was more to do....
Replace O/S/F hub seal.
Replace rear wheel cylinders,
Replace rear brake flexi pipe & T piece.
And I still have to;
Replace the front indicators & sidelights.
Fit new wipers blades.
Clean out the handbrake drum.
Sort out my parts store/scrap heap (depends on your point of view).
Remove the old tyres from the LWB rims.
Thats it for now, unless theres something I've forgotten
Hmmm!
These are quite tame lists so far.
Here goes.
Disco
1. fit steering box seal kit (parts ordered)
2. Fit de-cat front down pipe (have parts)
3. Remove first silencer box (have parts)
4. fit up rated intercooler and silicon hoses (have parts)
5. fit new front disks and callipers (have parts)
6. fit box section over sills and add rock sliders (have parts)
7. fit new valve top hats (waiting parts)
8. change timing belt (have parts)
9. change aux belt tensioner (parts ordered)
10. find and fix footwell water leak (waiting miracle)
11. fit dan bars and track rod ends (parts ordered)
12. repair inner wings
Bobtail Range Rover pickup
1. fit new inner wings (have parts)
2. fit 3.5 efi engine (have parts)
3. cut down and fit rear wings (have parts, thanks Dave)
4. make rear floor section (have alli plate)
5. new wheels and tyres
6. fit replacement windscreen (have parts)
7. fabricate new fuel tank
8. make rear bulkhead
9. finish rear chassis work for Bobtail
10. fit replacement drivers door (have parts)
11. repair passenger side foot well (have parts)
Tomcat
1. Finish chassis work and paint it
2. fit body panels (have parts)
3. build up engine (have parts)
4. fit engine and auto box (have parts)
5. have props made to suite Disco 2 axles
6. fit fuel system
7. fit megasquirt (have parts)
8. Wire up
9. paint body
10. fit windscreen
11. fit seats
12. fit rear mount radiator
'D' reg Range Rover
1. fit new rear fuel pipe to cure fuel leak (have parts)
2. fix exhaust blowing
3. fit rear shocker lower bushes (have parts)
4. re-MOT
'F' reg Range Rover
1. chop off body and make something interesting out of what’s left (have most of parts)
Not an exhaustive list and I am sure I will have missed loads of stuff. I am wondering now whether this was such a good idea of writing it all down as it may fall into the wrong hands and be suitably used against me at every available opportunity.
Here goes.
Disco
Tomcat
6. fit fuel system
8. Wire up
9. paint body
10. fit windscreen
11. fit seats
'D' reg Range Rover
4. re-MOT
'F' reg Range Rover
P gasket leaking slightly - Done
front prop sliding joint a bit loose (and UJs once a year without fail Sad )
rear stub axle has pitting on the hub seal face, needs replacing to stop hub seal failure every few K miles. - stopped leaking by itself, aint broke then dont fix it.
rear wiper motor needs replacing (never use it which is why it probably died) - who cares, never used it anyway.
front diff pinion oil seal leaking, could be a blocked breather - blocked breather unblocked.
refit winch
replace plastic light surround on wing, after hitting a tree. - done
replace a wheel arch spat - see above tree (sat in garage) - done
more things to add to list-
hole in exhaust - FIXED
possible fuel leak - new tank fitted
refit winch
300 TDi Back Axle to fit (already have, c/w disks, calipers and prop)
New passenger and safari door (need to purchase)
New set of barrel locks (see above doors - came with vehicle)
Off-road wheels and tyres to fit
New seats to fit
Dash and trim needs TLC
Steering guard and diff guard to acquire
Rock sliders to acquire
Chequer plate patches to fit where corroded ally has been treated (acid etched and primered)
That's it for starters, oh, and some attention to bulkhead before it becomes an issue
New seats to fit
"It seemed like a good idea at the time..."
