Axle Identification
Axle Identification
As my motor is a bit of a 'bitza' I'm not sure what front axle I have.
The brake caliper is the pin type not the spring type but that is where my knowledge ends. Is there any other outward signs to give me more information. I need to replce the CV's and possibly the diff.
How can I tell how many splines it has.
Can you tell without taking hub apart which CV's to buy.
sorry for my last - should have said they all have 24 splines at the drive flange........
my bad
AEU2522 - 23/24 wide pre' 200TDI 10 spline diff
RTC6862 - 32/24 wide 200TDI 24 spline diff
TDJ000010 - 32/24 narrow 300TDI til current. 24 spline diff
easiest way to tell is the drive flange itself. If its a big beefy wide flat affair - then its an early 24 spline RTC6862 or 10 spline AEU2522.
if its a more fine looking moulded flange like this - then its TDJ part
just thought, if its the later style thin cv they should be the same as the ones in your disco, as i think your disco was a 300tdi.... in which case you can use them. part numbers for disco, rangie and defender narrow CVs are all TDJ000010
my bad
depends if them there radius arm bolts come out.
i ended up cutting 3 of the 4 bolts to get my arms off the front axle when i rebushed it. 2 of those then needed a bar welding to the bolt head so i could give them some wollop with tool no.1 to get em out.
major pain in the proverbial.
