discovery sidelights
Postby nicks90 » Wed Jul 08, 2009 9:00 am
hello folks,
yet again the helectrikery of the disco 2 confuddles me!
just had the disco MOT'd and got an advisory that the front sidelights dont work. He`s checked the bulbs and they were fine and couldnt find any of the fuses in the box that relate to the side lights, so he was a bit stuck on what might be causing no sidelights at the front. (work fine on the back).
however he did notice that 2 fuses had blown - but nothing seems to be amiss though, very strange. There was a 40amp fuse that had the icon of a radiator with a fan in front of it :?: - but the disco has a viscous fan. and one of the fuses that has the icon of a book had blown too.
he`s replaced both fuses, but nothing seems different to before, so no idea what those fuses do. But the front sidelights still dont work.
Anyone have any idea what might be causing the front sidelights to not work and / or have a list of what each fuse does?
cheers
Nick (i aint no electrician) Clayton
Postby davew » Wed Jul 08, 2009 9:52 am
Have you checked both fuse boxes ?
Is it just the front lights ?
The sidelights go through both fuse boxes. Under the bonnet they go through link 12 (30A) and then they split left and right in the internal fuse box after the switch. (fuses 11 and 33)
For it to effect both front sidelights without effecting the rear tail lights would be very odd. If the tail lights are OK it's not the fuses. The sidelamp circuits are split left and right, not front to rear so if a fuse had blown you'd lose either lh front and rear or rh front and rear.
I'd start by checking the wiring is actually connected to the light units and work back from there...
I've attached a pdf of the wiring diagram.
Disco II sidelights.pdf
Disco II light wiring diagram
(160.15 KiB) Downloaded 2045 times
Postby davew » Wed Jul 08, 2009 10:00 am
This is an extract from the owners handbook re fuses and their uses... I couldnt remember which MY yours was so plumped for 2003
Disco II fuses.pdf
(618.34 KiB) Downloaded 4717 times
Postby nicks90 » Thu Jul 09, 2009 1:06 pm
cheers dave - i will have a poke about this weekend and see what i can break.... i mean FIX!!!
:lol:
Postby bandiflip » Thu Jul 09, 2009 3:07 pm
BUY A P38 !!!!
Postby Matthews » Thu Jul 09, 2009 5:54 pm
I'd like to know which MOT station gave you an advise for non working sidelights as it should be a fail, will be and a fine if you get stopped by pcplod, anyway let us all know and then we know where to take dodgy motors for a test.
Postby nicks90 » Fri Jul 10, 2009 8:49 am
that'll be a secret matthew!
8)
