Well the discs are here - have been for over a week now, but I appear to have lost my impetus. This happens now and then, when I just look at it and think to myself that it's just too big a job and it will never pass an MoT and the insurance will be too much and it's just a wreck and... and... and finally - I'd rather watch snooker or bike racing.
Please - if you know anything about motivational techniques - say something to cheer me up and get me going again...
Yesterday afternoon I replaced one spring and removed the front anti-roll bar. That's all for four hours work. It went something lke this:
Try to remove the split pins in the AR bar TREs. (20 mins). Then give up and just undo the bolts, shearing the pins. Should have done that from the start.
Try to crack the AR bar TREs from their tapers. (40 mins). Then give up and cut through AR bar with disc cutter. Cutter snatched and I put a nick in the track rod. Twenty minute verbal self-abuse and checking the condition of the Disco track-rod. It looks ok, but I'm not looking forward to changing it. Severely tempted to get some heavy duty Paddocks rods instead which will have the benefit of new TREs:
http://www.paddockspares.com/pp/RANGE_ROVER_1986-1994/Steering/Heavy_Duty_Steering_Rods_for_Range_Rover_Classic_and_Discovery_1_-_with_3_track_rod_ends.html but have resisted for now.
Remove the lower shocker mounting and loosen the upper. Remove the four shock-tower mounting nuts. Then (in order to get room to slide out the tower/shocker assembly) I set about removing a load of LPG and Megajolt related stuff that has been assembles around the tower position. Went ok but was fiddly and frustrating.
Now - with the correct placement of various jacks and axle stands, I remove the spring. Surprisingly I had to compress* it to get it out.
Next replace the bump-stop. Removing the old one I cut the bolts which are seized but loose due to corrosion - and then remember that they slide out. D'OH! Still, they are no good anyway. Luckily I then find that the chassis in this area only has a little surface rust and is soon cleaned up and given a quick blast with the Waxoil.
Fitted new bump-stop and new spring. Re-assemble all the stuff I stripped out for access and (I can't resist this) put the wheel back on and get it off the jacks & stands to see how it looks. Very pleased to find it now sits approximately 1
1/2" higher than it did at the front, which matches the rear nicely. I bounce around on the bumper corners for a while confirming that the dampers are fine
That was it. Pathetic progress and now (Monday) it's raining. <glum>
TTFN
* Spring Compression: I have a technique using two ratchet straps which would probably be frowned upon by professionals but seems to work ok. The only problem is they are rather speedy when releasing the tension - this operation is usually performed wearing welding gloves and a full-face helmet and with a large cushion between the spring and my vitals...
