Novice building a wreck!
Postby Rod » Fri Feb 12, 2010 9:38 pm
David, this is Bo on Rod's logon, from the pictures I have to say it doesn't look too bad. One thing to bear in mind is that you need to measure from the centre of the wheel hub to the body line on the wing front and rear to establish if it is sat level. Measuring to the underside of the arches is okay fro checking side to side but not back to front.
Postby Bo » Sat Feb 13, 2010 12:09 pm
David, I have just measured my Disco which has 2" lift springs all round and it measures 23 1/2" hub centre to the bottom of the body swage line at the front an 24 1/2" at the rear.
Hope this helps.
Postby tecnick » Sun Feb 14, 2010 4:47 pm
Hi dave, I agree with Bo, mine is roughly the same bar a few mill but my boot is full of junk. Mine has bearmach blue two inch lift and sits back. Dont recommend bearmach though, too soft.
madcalc
Full Name: david medd
Postby madcalc » Thu Apr 01, 2010 9:58 pm
finally finished motor after 6 months and passed MOT (with a little help from Mr Sykes!) :D changed signature from "yeah! I dont't know what I'm doing" see the before and after pictures Thanks to everyone for all the advice given 8)
Postby davew » Thu Apr 01, 2010 10:04 pm
That looks better !
Postby tecnick » Fri Apr 02, 2010 7:40 pm
Looks great Dave, now you can join us all in destroying it :!:
Mine is due its MOT end of this month, I'm sick of of these government tests lining the Sykes pockets. :twisted:
Postby Matthews » Mon Apr 05, 2010 4:44 pm
If you looked after it and maintained it on a regular basis then it wouldn't be an issue , I had to put all 3 of mine through MOT last month and only 1 cost me any money (annoyingly a front wheel bearing on the Disco so big bucks :( )
