- Full Name: phil johnson
Postby bandiflip » Mon Aug 09, 2010 3:55 pm
Been out in the yard today and begun to strip out all the back end....Unfortunately Mr.Tinworm has been busy so good job its getting chopped!
I'll do some more tommoro which will probably be wiring and fuel tank out...then its on the fone to my bestest friend Bo !!
- Full Name: Nick Adams
Postby tecnick » Mon Aug 09, 2010 7:41 pm
It will be back on the bay before the tank comes out
There is only Alec who sells things as fast as you.
- Full Name: James Poulton
Postby jim » Mon Aug 09, 2010 7:48 pm
Why not turn it into one of these
Postby bandiflip » Mon Aug 09, 2010 9:49 pm
Postby Bo » Mon Aug 09, 2010 10:58 pm
Next stage is a piece of 25mm square wood, two masonry nails and a drill bit just smaller than the nail diameter.
Postby bandiflip » Mon Aug 09, 2010 11:17 pm
Postby davew » Mon Aug 09, 2010 11:31 pm
Bo wrote:Next stage is a piece of 25mm square wood, two masonry nails and a drill bit just smaller than the nail diameter.
That's all very well but what does he need for the bobtail ?
Postby bandiflip » Tue Aug 10, 2010 5:42 pm
and a bit further......going to cost a fortune in chequer plate !!!
Postby bandiflip » Tue Aug 10, 2010 5:46 pm
good old tin worm has been busy !!
Postby Bo » Tue Aug 10, 2010 8:33 pm
Its a good job most of the rot will be going, but I have seen and repaired much worse. You need an 8x4 sheet of 5bar ali chequerplate for the floor. A mate of mine has just bought some sheets for his recovery truck and paid £50 a sheet.
The piece of wood with two nails spaced the distance apart you want to bob it by ensures the right amount is removed by scribing a line in from the existing joint.
Postby bandiflip » Wed Aug 11, 2010 12:03 am
- Full Name: tony
Postby Rod » Wed Aug 11, 2010 11:34 pm
Phil
If you want to have a look at my Rangie to get some ideas of how we did it (mainly Bo that is, i did make the tea as thats the most important job, so Bo kept telling me !!)
I also took some photo,s if you want a copy of these, I could put them on a disk, there are some on my build page
Postby bandiflip » Thu Aug 12, 2010 12:15 am
Yeah That'd be good !...Bo is comin over Saturday morning to have a look at mine.....I'm looking forward to chopping it up!!
Goin to be a pick up !
Postby Bo » Sat Aug 14, 2010 2:10 pm
Not sure if me and Rod were much help this morning Phil, but here's a plan B, C, D and E.
I particularly like the exposed front end on the Allegro picture
Go on, you know you want E.
Plan E
http://www.adrianstomcat.co.uk/4DrTrayback.htm
Postby bandiflip » Sat Aug 14, 2010 4:11 pm
Hmmmm....looks like the cage on the Sierra is actually holding the body on!!
If i turn up at a trial with anything like those.....somebody please shoot me !
