Re: While you were out enjoying yourself..
Postby TwoSheds » Tue Jul 21, 2009 6:00 am
After work last night I re-assembled the rear brakes (I had forgotten about them!) and replaced the servo and master cylinder.Three out of four brake pipes on the master cylinder needed re-making due to the pipe twisting up :x You know it's about time somebody came up with brake components/design that are serviceable.. I sorted two of the pipes, but I still have one to re-make because it got too dark :(
I'm getting all enthusiastic again since hearing the engine yesterday - I'm having difficulty resisting the temptation of getting Mr Sparky going and starting down the pickup/king-cab route until after the MoT :) :wink:
Postby Matthews » Tue Jul 21, 2009 8:23 pm
Been using hozelock sprayer at wk for 2.5 years with ATF, MTF and EP, slow but very effective and gives you chance to make a brew as it fills things up for you, if you know the capacity you can also fill the sprayer to just about the correct amount.
Postby TwoSheds » Tue Jul 21, 2009 9:20 pm
Matthews wrote:Been using hozelock sprayer at wk for 2.5 years with ATF, MTF and EP, slow but very effective and gives you chance to make a brew as it fills things up for you, if you know the capacity you can also fill the sprayer to just about the correct amount.
Thanks Matthew - that's good to hear, I half expected to walk into the garage this morning and find a soggy red mess where it used to be :)
Tonight I got the replacement brake pipe made and fitted and I fitted the seats, crash-switch and seat-belts - at this rate I'll be running out of excuses soon!
p.s. Does anyone use those pressure bleeders or know which are the best type?
p.p.s. With new ATF in the LT77 I can now get into first gear without going via fourth :) Not surprising there is an improvement - the old stuff was like ditch-water :o
Postby nicks90 » Wed Jul 22, 2009 9:45 am
yep, i have an eezi-bleed sat in my garage you can borrow if you can get round to ossett.
has all the different cap sizes too.
got a gunsens gas wotsit autotune in there too somewhere, not that i need it, as i havent run a petrol motor since my old mini........
Postby dave willard » Wed Jul 22, 2009 10:33 am
If eventually the seals etc perish you can gat a complete set from gargen centes cheaply
Postby TwoSheds » Wed Jul 22, 2009 10:35 am
nicks90 wrote:yep, i have an eezi-bleed sat in my garage you can borrow if you can get round to ossett.
Thanks :) but it would probably cost more in fuel than to buy one!
I have an old colortune too - great bit of kit if you run carbs - there's not much I can do about mixture on the EFI though ;)
p.s. Just found an eezibleed for £15 inc delivery tomorrow so I'm going for that.. :)
p.p.s Bugger! I didn't realise that Ossett was so close (I'm an incommer you see, don't know my way round yet) - I could have saved myself a few squids there!
Postby TwoSheds » Fri Jul 24, 2009 4:28 am
Got the Eezibleed and it's great! Since I split the clutch line for access during welding, I have had several goes at bleeding it with my neighbour pumping and me underneath using possibly THE most awkward bleed-screw ever. Needless to say I got nowhere. Ten minutes by myself with the Eezibleed and it's sorted! :D
Unfortunately I ran out of fluid beefore I finished the brakes, but at least now I can move the car around under it's own power :)
Good piece of kit, but should come in a better container for workshop storage.
Postby TwoSheds » Fri Jul 31, 2009 4:54 pm
MoT tomorrow... (worried) It's really just a shell at the mo (no trim or door-cards etc) Unfortunately the drivers window winder decided to go this morning so some of the time I would have spent on checks went on replacing that. Sorted now though.
Just tested the brakes - pulled up good and straight but strangely locked both fronts when really hammered - I would have expected the backs to lock - especially with not having any trim or seats in the rear.. Only thing I can think of is that the front discs are new and the rears are a little rusty.
Got a two mile straight on the way to the MoT, so will probably go along there in third or something to give it a bit of a blow through.
While I was testing the brakes just now I gave it full throttle in 2nd from a walking pace up to about 30, and BOY does it shift! It makes the old Disco look a bit sad, well actually it makes it's old SELF look a bit sad too! I can't emphasise enough the benefits of decent ignition - anyone who is still running a dizzy should definitely Jolt it :D
Got to go now - I'm out at Shakespeare at the Abbey tonight, so final fettling will be tomorrow morning. If I am strangely quiet tomorrow afternoon you will know what's happened..
Postby davew » Fri Jul 31, 2009 5:38 pm
Fingers crossed !
Postby TwoSheds » Sat Aug 01, 2009 12:42 pm
Not even an advisory and he complimented me on my welding...
Postby pamw » Sat Aug 01, 2009 12:50 pm
Yayyyyyyy!
Well done Roger!
8)
Postby bandiflip » Sat Aug 01, 2009 12:55 pm
EXCELLENT JOB !!!...Well done Roger...See you at Lothers hill cross dale...what ever its called !
Postby repton » Sat Aug 01, 2009 7:53 pm
Well done. It must be a good day for MoTs as my 110 passed this morning. First time in years I've got a green piece of paper at the first attempt!
Postby TwoSheds » Sat Aug 01, 2009 8:27 pm
repton wrote:Well done. It must be a good day for MoTs as my 110 passed this morning. First time in years I've got a green piece of paper at the first attempt!
Congratulations! :D
Postby TwoSheds » Sun Aug 02, 2009 7:11 pm
Had a productive day today - got the rear recovery point sorted:
ImageNot a bad departure angle for a 'standard' Range Rover :) The bumper is standard but with a scaffold tube welded inside and heavy duty mountings.
I also put the one-shot in the front hubs - didn't want to do it before the MoT just in case ;)
Then I played with the ignition maps - doing road tests on both gas and petrol and I am really happy with the result :)
Performance test: Third gear accelerate from 40mph at one road sign and check speed at the next. Petrol - 53mph, gas - 52mph.
Flexibility and (self-imposed) 5000rpm rev limit test: From below tickover - flat out in 2nd - engine pulls strongly all the way to 5000rpm and then goes flat as a fart. Same for petrol and gas.
Only one leak found so far - I appear to have a weeping rear crank seal. Probably not worth worrying about but I will keep an eye on it. It might have been there all along (can't remember) or maybe the long layup caused it.
After today's runs the emissions now seem fine - on gas I reckon I could almost breath the stuff neat! :lol:
Still got so much to do, but at least I can play with it now.
