Things that go bump...
- Bo
Jabba wrote:WeldUK had a new swan neck for about £14 as I can replace just that and not need the gas switch block. I've also ordered some tips from them.
Its amazing the difference a new good quality liner makes to the weld if the old one is worn, I would be tempted to change that as well if your doing the rest.
thats the next job i need to do on my welder when i need it next - supposedly net curtain wire is an extremely good wire feed liner and cuts down the wire friction wonderfully giving a nice smooth feed.
- Jabba
- Full Name: Dave Ladell
Got a bit more done today. The bottom mounts are on and welded and holes drilled. I need to trim the back of the plates a bit to allow the captive nut holder thingy to fit.
Shaping up well. Might have to trim the ends a bit more though as it sits a bit wider than I expected.
- Bo
nicks90 wrote:Its amazing the difference a new good quality liner makes to the weld if the old one is worn, I would be tempted to change that as well if your doing the rest.
Hi Nick, not being a curtain expert, how much are they as a new 3m 'Propper One' is only a fiver or so.
new liners for my stupid SIP welder are a few quid more than that as they use a plastic liner. So not only is it dearer, its rubbish too. If i had known what bad reviews SIPs get on on various forums i wouldnt have bought it, no wonder it was cheap.
curtain wire is about 50p from the market - or free to me as my neighbour makes bespoke curtains and has tonnes of the stuff
nicks90 wrote::lol: at Bo
Hi
I have had my clarke mig for 20years
I use machine mart for consuables but have also used SIP parts as they sre the same (lining swan neck tips etc)
one advantage is that MM are open weekends (LEEDS BRADFORD BARNSLEY when a spare is needed in the middle of a project
Look online
Also Screwfix stock wire & tips etc again open late eve & weekends
Also look in B & Q
- Jabba
Bit more done this lunchtime...
Got the slots cut for the top mount plates as they have to sit through the box section. Plates in place and tack welded ready for checking the hole placement and seam welding.
Also went round and removed some of the bird poo welding elsewhere and re-did it so that it won't fall apart at the first tug!
- Jabba
- Jabba
Just had a word with Marlyn and they can't bend the bar for the recovery loops (well not for sensible money) so I'm going to do it myself.
I've got the 16mm bar and can make up a jig to shape it on but thought I'd check if anyone else has done this before...
They suggested setting two tubes in a base that could be clamped in the vise and the rod inserted between them. Then gradually shape the bend round the tube. The shape I need to make is below. The odd length legs are to allow the top one to be welded along the mounting plate.
Also, I've only got a butane brazing lamp to heat it with. Will this be enough, or does anyone have a small oxy set I could 'hire'?
Any suggestions welcome (even sarky ones
wouldnt it be simpler to just fit a couple of swivel recovery eyes to the front bumper instead?
these ones even come with the bow shackles.
http://www.firstfour.co.uk/recovery-poi ... 363808.php
