No its not broken its just an ongoing resoration project )
davew wrote:You can weld stainless with a MIG using normal mild steel wire/gas, you don't need anything special for it for something like an exhaust. The weld pool fuses with the stainless anyway and seems to become "stainless" itself, resisting rust.
I did mine with gas-less mig and it's still in one piece three years later, although at the time I was not confident in welding SS like this so I layered a bit on just in case
I even managed to get it gas tight by using leak detector and a rag up the outlet and puddling the little blow holes.
I probably wouldn't be happy welding anything that is stressed in this manner, but the last few inches if pipe is fine - especially if it is out of sight
- Zedman
- Full Name: Richard Bentley
You learn something new every day
You learn something new every day, thanks for the info and offers of help, but armed with the idea that stainless can be welded like normal steel and that fact I just needed to add a cosmetic / rounded edge to the end of the exhaust pipe I fired up the old arc welder and 'the jobs sorted'
- Zedman
What colour is my paint )
The back end has now been re-wired, I have thrown away god know how much wiring loom and replaced it with 1 single length of 7 core, new lights installed / repositioned etc, blanking plates made to cover old holes, but since its Q plate and no VIN number I am struggling to get a paint code.
Most of you have seen my Defender an the last trial can anyone in the know please take a guess at the paint code and suggest a place to buy spray and brush on paint ))
