Exhaust nuts
Exhaust nuts
Postby TwoSheds » Mon Apr 26, 2010 5:48 pm
I couldn't find the nuts which hold the Y pipe to the manifolds, so I have used stainless nylocs. Now It's obvious the nyloc bit will melt so I put spring washers under the nuts, however I am now uneasy that the SS nuts will somehow become 'welded' to the studs... I was a b@ll-aching job getting the nuts on (took two hours of fiddling) so I don't want to replace them unless I need to... Whadayathink? Change them or leave them?
Postby bandiflip » Mon Apr 26, 2010 5:53 pm
Well If you need to remove them....why not do when you need to...not now coz you want to???..If ya get my drift?
Postby TwoSheds » Mon Apr 26, 2010 5:57 pm
I was thinking that if they are going to cause trouble then I would rather take them off now than break the studs yousee...
Postby tecnick » Mon Apr 26, 2010 8:12 pm
Wont it be less likely to weld together? I would have thought that stainless would have a higher melting point than mild steel.
Postby davew » Mon Apr 26, 2010 8:34 pm
I wouldn't worry about it Roger, SS does tend to "weld" to other SS fittings so a SS nut on a SS bolt will be a pain to undo later. A SS nut won't be as likely to stick to a HT steel stud though and I'd have thought would be less likely to cause a problem in the future than a HT steel nut.
No sign of the paperwork from DVLA yet then ? :)
Postby TwoSheds » Tue Apr 27, 2010 5:25 am
davew wrote:I wouldn't worry about it Roger, SS does tend to "weld" to other SS fittings so a SS nut on a SS bolt will be a pain to undo later. A SS nut won't be as likely to stick to a HT steel stud though and I'd have thought would be less likely to cause a problem in the future than a HT steel nut.
Thanks Dave - I feel happier now.
davew wrote:No sign of the paperwork from DVLA yet then ? :)
I rush through the house like a little boy every day to check - but nothing yet... :(
