Brake caliper / disc to hub bolts.
- Full Name: Paul Everett
Is there a proper name for the sort of bolts used for brake calipers and to bolt hubs to discs? I've been using a 1/2" double hex socket so far and it has worked but too much use of a normal socket with a windygun has killed it and I figure if there's a "proper" tool for the job it's probably time to get one as my impact sockets are all single hex and so don't fit.
- Full Name: phil johnson
You've pretty much answered your own question there ..... They're just double hex bolts that need a double hex socket.... Never seen impact double hex sockets so looks like you're gonna have to buy either a new socket or go to a nut n bolt suppliers and match the bolts up but with single hex heads.... Simplez
Matthews wrote:just buy a decent 12pt socket and you should be ok , cheap ones will break
Indeed, I have managed to break mine but it was only a cheapy from a socket set I bought when I was in my teens. I have now got a decent replacement on the way.
I had great fun today in the rain doing the driver's side front wheel bearing. Whoever did it last managed to shear off three of the five M10 drive flange to hub bolts and had simply filled the holes with silicon and stuck the heads in. So I had the joys of having to get the remains out of the holes which wasn't much fun. I'm slightly surprised that it managed driving through just two of them, no idea how long it has been like that.
It's all done and back together now though.
- Bo
Snap-On do 12 point impact socket but obviously you pay the price.
Or use Franklin http://www.ebay.co.uk/itm/Franklin-1-2- ... 3ce113aafa for considerably less.
