Crankshaft oil seal to timing case
Crankshaft oil seal to timing case seems to be leaking quite a bit of oil, any hints tips and guides on changing this seal would be appreciated, have changed timing belt and the modified timing tensioner so have been very close to the seal, is it easy to get out, any secret "Mathew's make the job" easy tips i need to know ?
Re: Crankshaft oil seal to timing case
Zedman wrote:Crankshaft oil seal to timing case seems to be leaking quite a bit of oil, any hints tips and guides on changing this seal would be appreciated, have changed timing belt and the modified timing tensioner so have been very close to the seal, is it easy to get out, any secret "Mathew's make the job" easy tips i need to know ?
Hi
have you done it yet if not talk to me you dont need to remove the case there are easy ways to insert the eeal using reversed pulleyetc
also buy several seals they are cheap you can afford several goes
are you syre its not the cam seal very very easy to damage when putting the pump on I have a tool to make this easy may be worth getting one of these seals as well
I have seval seals if you want them
dave
