Aluminium welding
Aluminium welding
Postby nicks90 » Mon Apr 04, 2011 11:53 am
does anyone on here know of someone that could do a small spot of ally welding in the wakefield or Barnsley area?
My mate has a very stupidly expensive bike and has managed to develop a crack in the frame. Its 'Alpha aluminium", which apparently is just extruded aluminium, and its got a hairline crack on a load bearing joint.
any help would be mucho appreciated.
nick
Postby olzook » Mon Apr 04, 2011 6:16 pm
Personally I wouldnt risk it.
How old is it? Take it back to manufacturer.
Cycle frames can be put under a lot of stress (especially if I'm riding it) and if it fails as a result of an attempted repair and pitches your mate under passing traffic, then not good at all.
Get a warranty claim on it or put it in the bin.
Postby Bo » Mon Apr 04, 2011 6:37 pm
Alpha Aluminium will some form of trade mark, it is not a description of the alloy which usually goes from LM0 which is base aluminium upwards as other elements are added to improve workability, strength or machinability. Most engines and heads are LM25 which is a heat treatment alloy or LM226 which work hardens.
You must always repair aluminium with a like for like filler rod if you are to maintain its integrity and then heat treat it to harden/normalise it.
Short answer, don't do it!
Postby bandiflip » Tue Apr 05, 2011 12:33 am
I have to agree with Oliver on this one,Its actually cracking for a reason,you could be masking a MAJOR problem with the frame which is a big NO NO on a bike,especially faster and dearer ones....He needs to get it checked out properly really.
Postby olzook » Tue Apr 05, 2011 8:38 pm
bandiflip wrote:I have to agree with Oliver on this one
Thought you always did :wink:
Postby bandiflip » Tue Apr 05, 2011 8:50 pm
Ya know what thought did
Postby TwoSheds » Wed Apr 06, 2011 5:27 am
bandiflip wrote:Ya know what thought did
I NEVER understood that phrase... :shock:
