Alternator
problem with very high output alternators is if you get a big battery drain - eg winching - the alt will try and shove it all back in one go. The wiring will need upgrading to cope with potentially 230amp instead of the 90 it currently uses and your serp belt might slip a bit with the effort.
Kingson
Kingson, I belive you have 2 batteries so there should be no need to run such a high output alternator.
there are probably loads of campanies that can refurb your old one also
http://www.auto-generators.co.uk/alternators.htm
http://www.unit-exchange.co.uk/car-alternators.html
scrap yard might also be a good option )
