RRC EFI Multi-vent fuel tank replacement - what's best?...
My tank is pretty rusty and although it doesn't leak, the mounting flanges are well corroded and I am thinking of replacing it.
So-o-o-o...
Paddocks do a bare tank at £76 and I was thinking of transferring my pump and sender unit to one of those.
But: The sender unit looks like it could be a bit of a bitch to get out with it's well-rusty retaining ring and special tool required... (Landrover Special Tool #1 - hammer and Landrover Special Tool #2 - cold chisel
Has anybody done this before who can offer any advice before I start to butcher the tank?
Alternatively - are there any other alternatives?
Cheers,
So-o-o-o...
Cheers,
Make sure you get the protection plate that fixes to the bottom of the tank. Fill the gap between the tank and cover with waxoil and sesl the edges with a petrol resistant sealer - tiger seal for example.
If you haven't got one already, make sure to cut an access hole in the floor above the pump.
Get a new sender retaining ring and seal with the tank
I still have the tank I took out of my rangie, it got some surface rust but nothing that can not be put right
- Attachments
- Petrol Tank.doc
- (838.5 KiB) Downloaded 1507 times
Many thanks for the replies
Rod - yours looks fine to me, how much do you want for it?
Matthew - thanks but it's easier to go with Rod's offer.
Dave - I haven't got a protector plate (I always thought that the standard one looked a bit flimsy anyway) - I'll keep my eye out for one (or maybe just wait until I can afford a more solid after-market one...)
<EDIT>
Rod - I just noticed that your tank looks to be a single vent model. Does this matter? (I am not keeping the behind-the-wing collector anyway because it's in the way of my lpg filler)
<EDIT>
Matthew - sorry I didn't get in touch about the mounting plate - I had to change my pump into Rod's tank and so have been held up a bit until I can get a gasket...
Interestingly, according to the drawing in my official RR Workshop manual (biggest waste of space on my bookshelf) there is no support plate on my model... But I would rather trust you than it so... Could you let me know how much you want for one and if you could bring it along to the club-night please?
