Crankshaft oil seal to timing case
Postby Zedman » Mon Apr 11, 2011 7:44 pm
Crankshaft oil seal to timing case seems to be leaking quite a bit of oil, any hints tips and guides on changing this seal would be appreciated, have changed timing belt and the modified timing tensioner so have been very close to the seal, is it easy to get out, any secret "Mathew's make the job" easy tips i need to know ?
Postby Matthews » Mon Apr 11, 2011 9:02 pm
Fraid not , pull the front end apart again, oik it out n fit a new one then put it all back together.
Re: Crankshaft oil seal to timing case
Postby dave willard » Thu Apr 21, 2011 1:48 pm
Zedman wrote:Crankshaft oil seal to timing case seems to be leaking quite a bit of oil, any hints tips and guides on changing this seal would be appreciated, have changed timing belt and the modified timing tensioner so have been very close to the seal, is it easy to get out, any secret "Mathew's make the job" easy tips i need to know ?
Hi
have you done it yet if not talk to me you dont need to remove the case there are easy ways to insert the eeal using reversed pulleyetc
also buy several seals they are cheap you can afford several goes
are you syre its not the cam seal very very easy to damage when putting the pump on I have a tool to make this easy may be worth getting one of these seals as well
I have seval seals if you want them
dave
Postby Matthews » Thu Apr 21, 2011 7:12 pm
Dave you can't get to the crank oil seal without removing the belt/cambelt bottom drive pulley as its behind that , he's not talking about the timing case front seal but the crank oil seal.
