What wing?
What wing?
Postby varleym » Fri Mar 11, 2011 9:20 am
All
Fitted the new wings some time ago and need to buy a set of indicator repeaters for the sides (my original wings didn't have them on), however looking on Fleabay there seems to be different variants for 300Tdi and TD5 wings and I don't know which ones I've got. They have the larger holes for the newer side/indicator lights and I've taken a photograph (below) of the 'hole' for the repeater.
Can anyone advise whether I need 300Tdi repeaters or TD5 repeaters?
Thanks in advance.
Postby davew » Fri Mar 11, 2011 9:26 am
TD5, you can also fit the clear version which I think come from Freelanders ?
I use the clear version on mine, I'll be able to tell you the part number this afternoon as I'm off to pick one up from Maddisons - Mike lost one of mine in that boggy bit by the concrete shed on Sunday... :)
Postby varleym » Fri Mar 11, 2011 11:33 am
Lol - that's co-drivers for you :)
Postby varleym » Fri Mar 11, 2011 11:35 am
Presumably if you use a clear lens you need to have a coloured bulb then?
Postby davew » Fri Mar 11, 2011 11:39 am
Yes, the lenses come with the appropriate bulb already fitted anyway.
Postby varleym » Fri Mar 11, 2011 11:44 am
Would you be able to pick up a couple for me? I'll call in tonight & collect them and give you some dosh?
Postby davew » Fri Mar 11, 2011 12:11 pm
I'll give you a call and let you know if they have any more in stock.
Full Name: Dave Barker
Postby Dave » Fri Mar 11, 2011 4:38 pm
Td5 / Freelander 2. Try Bolt on Bits for the lamps very cheap around 1/3 the price of Land Rover
www.boltonbits.net
you can get the lens in a host of colours from orange to clear
Dave:
Postby kingsonlim » Fri Mar 11, 2011 5:16 pm
Mark,
If you do decide to get the side repeaters from Bolt-on bits....I can pick it up for you, as they are only 5 mins from me.
Kingson
Postby varleym » Fri Mar 11, 2011 11:11 pm
Sorted now - thanks Dave.
Users browsing this forum: No registered users and 4 guests
