timing belt on 300tdi
Postby Matthews » Wed Nov 10, 2010 5:40 pm
Kinsom , take it all apart again , smear the o ring with grease, fit it onto the crank and put back together again, if you don't your front timing belt cover will slowly become coated with oil and it'll perish the belt, back to square one again.
Postby Bo » Wed Nov 10, 2010 6:08 pm
Richard, for piece of mind, if you use a small torch to look up the wading plug hole in the bottom of the cover, you should be able to see if the belt is shredding.
Good idea bo
Postby Zedman » Wed Nov 10, 2010 6:17 pm
Good idea bo, will take a peak at the weekend,
Postby kingsonlim » Wed Nov 10, 2010 6:52 pm
Matthews wrote:Kinsom , take it all apart again , smear the o ring with grease, fit it onto the crank and put back together again, if you don't your front timing belt cover will slowly become coated with oil and it'll perish the belt, back to square one again.
oh dang......will take it apart as soon as there's 'better' weather......
