Disco axle onto Defender
- varleym
- Full Name: Mark Varley
Hi all
Managed to source a disco rear axle from a 300Tdi to fit on my defender for the re-build and I had planned to simply swap the 3 bolt flange from the Disco diff for the 4 bolt flange on my Defender diff..........
However..............
When I removed both flanges, the disco one has a multiple (24?) splined shaft abut the Defender one is a 4 spline (effectively a 'cross'). I can't just swap the diffs over as the defender has 10 spline half-shafts and the Disco has 24 spline and I'm not even sure the half-shafts will be the same anyway (one being froma drum braked Defender and the other from a disc braked Disco). I'd rather retain the Disco diff/half-shafts anyway.
Had a quick chat with Mr White this morning (sorry it was so early Dave (10:00
) - forgot you probably don't surface until the PM on a weekend
) who said that the very early Defenders had this 4 spline flange but later ones moved on to the 24 spline, so...............
Does anyone happen to have either a flange or a diff from a later Defender kicking about that I can use or am I going to have to go and see the nice man in the parts department at Ripon Land Rover and try to explain what I need?
- tecnick
- Full Name: Nick Adams
- Bo
- Full Name: Scot Chegg
Dave covered this in his build, http://www.yorkshireoffroadclub.net/forum/viewtopic.php?t=601&postdays=0&postorder=asc&start=30
if you need any help, he's ye man.
- madcalc
- Full Name: david medd
