sealing a leaky sunroof
Postby TwoSheds » Wed Aug 04, 2010 6:05 am
Hi,
My sunroof is the metal kind with a furry edge and drains underneath and - while it doesn't matter that it leaks, I would still like to seal it since it will certainly never open again for various reasons... So the question is - how to seal it so I can remove the drains?
I thought of sili-sealer or Tigerbond, but I think that getting it to stick to green mouldy fur would be difficult, so I am contemplating glass-fibre over the outside a couple of inches wide (looks are unimportant to me, but you have probably guessed that..)
What does the team think? Any suggestions would be welcome...
roger
Postby bandiflip » Wed Aug 04, 2010 8:04 am
I've never done anything like this but i think a rubber or silicone based sealer would be better than fibre glass filler because of the flexibility.I think the glass would be too rigid and possibly crack or seperate giving more leaks!!
I would run sealant around the sunroof seal then when its dry,add more sealant on top of that then spread it out.
thats what i would do anyway
Full Name: oliver heselton
Postby olzook » Wed Aug 04, 2010 8:07 am
Why not take it all out. Then get the sheet alloy, sealant and pop rivets out and seal the roof in a permanent fashion :?
Postby tecnick » Wed Aug 04, 2010 8:29 am
I have seen this solution, handy,easy to use but not permenant.
http://cgi.ebay.co.uk/Umbrella-Hat-1148 ... 43a0b937f1
jim
Full Name: James Poulton
Postby jim » Wed Aug 04, 2010 8:51 am
Why not make it into a convertable :lol:
Postby TwoSheds » Wed Aug 04, 2010 12:43 pm
I take the point about cracking, but was thinking if I laid a 4" wide strip on sanded clean paintwork that it would be ok... perhaps not then!
Sealant (in my experience) usually leaks in the end no matter how much you put on, umberella - like it... ;) Sheet ally - the roof on an RRC curves in two axes so I would end up with a big gap somewhere...
Thanks for the ideas though folks :)
Postby davew » Wed Aug 04, 2010 2:58 pm
PU adhesive will sort it out. It lasts forever, is oblivious to nearly all solvents (including petrol), remains flexible and expands with the joint. Silicon is a waste of time by comparison.
Two caveats:
It's resistant to all solvents, try not to get it on your skin unless you enjoy scrubbing your skin until it's red raw.
Don't use it if you think you might want to open the sunroof again at some point without breaking it.
Available under a number of brand names and in different colours, make sure you get the adhesive type as there is a none adhesive version used for body fitting. Sikaflex and Tiger Seal are common brands at decent auto factors.
Postby dave willard » Wed Aug 04, 2010 4:21 pm
davew wrote:PU adhesive will sort it out. It lasts forever, is oblivious to nearly all solvents (including petrol), remains flexible and expands with the joint. Silicon is a waste of time by comparison.
Two caveats:
Lots of Sikaflex on ebay
Postby tecnick » Wed Aug 04, 2010 4:25 pm
I used stikaflex type stuff when I put roof on old ninety, it sticks like s**t to a blanket.
Good stuff.
Postby Matthews » Wed Aug 04, 2010 5:42 pm
If it's not leaking then why start messing with it in the first place !
Postby Matthews » Wed Aug 04, 2010 5:43 pm
Ignore last post as I've now read original correctly.
PU adhesive sealant or change to roof for one without sunroof in it .
Postby bandiflip » Wed Aug 04, 2010 6:03 pm
I like Jim's idea...MADE ME LAFF !!!!!!! :lol: :lol: :lol: :lol: :lol: :lol:
Postby TwoSheds » Wed Aug 04, 2010 6:46 pm
Votes are for Sikaflex then - will give it a go before w/e if I get a chance.
Matthews wrote:<..> or change to roof for one without sunroof in it .
That would be nice if I could find one for free since it would make the up-coming chop-job easier too...
Postby Rod » Wed Aug 04, 2010 11:53 pm
why not see Karl at cas 4x4 and see if he has a roof with out a sun roof in his yard
Postby TwoSheds » Thu Aug 05, 2010 5:52 am
Rod wrote:why not see Karl at cas 4x4 and see if he has a roof with out a sun roof in his yard
Good point - I bet he has several. I'll see what he would want for me to drive in with one and out with the other...
