rubber side strips, how do I remove the double sided tape?
That's it really - anybody got any tips?
I've removed the rubber side strips from my RRC (anybody want them? - free...) but it has left a manky, spongy, double-sided tape that was used to stick it on.
Tried scraping - ruins the paint.
Thought about solvents but best would be one that dissolves the glue but leaves the spongy middle strata of the tape so that I can pull it off.
Would heat (hairdryer) work?
Any suggestions?
Any suggestions?
Ketone based solvent should work OK without damaging the paint. Propanone (nail varnish remover without the perfume and colourings) is a handy one to use.
Failing that, get a can of MEK Durapipe Solvent/degreaser as this is pure Butanone. Also, you can mix this 10% with 98 Octane (summer blend) to give yourself a quick and easy AVGas Octane boost
"It seemed like a good idea at the time..."
- Full Name: Dave Leach
Nail varnish remover will probably remove the paint as well. Being in the furniture restoration business i have been called out to numerous dining tables that have had nail varnish remover spilt on them and it is as good as cellulose thinners at dissolving modern lacquered finishes.
I would try white spirit as this should dissolve/soften the adhesive without affecting the paint.
I'm not sure the effect it would have on the paint but i know that in the house i use lighter fuel (you know the small swan cans for refilling zippo's) to remove sticky marks and labels from things - i've not had damage to anything so far - well unless you count the time i set fire to something but that's a different story!!!
So it may be worth a try is nothing else works.
