300tdi Disco Auto gear selector
The gear selector in our 300tdi automatic Discovery has recently become quite stiff.
Where should I start looking? Are there any common causes? I assume there's a cable of some kind linking it to the gearbox but I'm guessing it's a pig to get at...
If it makes any difference to the answer I haven't had a chance to change the gearbox fluid yet. I've got the stuff but it's still in the can at the moment and not in the 'box.
TIA,
TIA,
I did that and to be honest with you it wasn't completely obvious still which the problem was. It moved more freely with the selector disconnected but probably not as freely as I might have expected. I've sprayed WD40 everywhere I can get at and also now changed (half of) the ATF. The old fluid looked quite unpleasant...
Went for a test drive and the selector seems to move more easily and the gearchanges are very noticeably smoother.
So I think for now I'll just leave it be and see what happens... The plan is to change the gear oil again and have the sump off and do the filter next time but exactly when that will be I've no idea as I'm very good at planning things but never getting round to them...
Ta,
Ta,
