Freelander 1 key fob programing
Postby Rod » Thu Dec 08, 2011 6:26 pm
Im having a problem reprogramming key fob after changing battery in fob.
r las put some thing on a-se about face book last night
but non of the ideas worked, so if any one has an idea please post below
Postby davew » Thu Dec 08, 2011 7:37 pm
Would I be correct in assuming the alarm is armed at the moment ?
If the alarm is on you can't re-sync the fob, you'll need to use the emergency access code to disarm it.
With the alarm disarmed, the book of words says...
The handset signals must be synchronized to the CCU. The synchronization
will be lost if the power supply to the vehicle or the handset is lost.
Synchronization can be reprogrammed by pressing the handset lock button five
times in quick succession with the ignition off. Alternatively, the ignition can be
switched to position II with the handset attached to the key ring, this will
automatically reprogram the synchronization. This is achieved by means of a
circular transponder antenna located around the outside diameter of the
ignition switch. For this to happen, the transmitter must be within 70 mm of the
ignition barrel.
Re: Freelander 1 key fob programing
Postby Bo » Thu Dec 08, 2011 9:51 pm
Rod wrote:Im having a problem reprogramming key fob after changing battery in fob.
That's why Simon won't fit them for you!
Did you discharge remote by pressing both buttons for 5 seconds without battery in? You should then be able to reprogram once new battery fitted by standing close to car and pressing either button 5 times in quick succession.
Postby Rod » Thu Dec 08, 2011 10:25 pm
Cheers Dave / Bo
I have tried the first one, Mathew suggested I did the same last night,
I have dischanged the fob as said below
I will try with the ingition on the second position tomorrow the wind is to stong tonight its blowing my hair into my eyes all the time making it hard to see,(I think I may have already tried this, but I can not remember which position the key was on 1 or 2)
Postby tecnick » Sat Dec 10, 2011 9:54 pm
Is the whole thred a big fib? Hair in eyes. I may be rubbish at elastictricary but I can't remember hair :shock:
Cheers nick
Postby Rod » Sun Dec 11, 2011 7:32 pm
Sorted
Went to four plus and bought a new on and they programed it in, it looks like one of the buttons was bust
Nick what do you mean I have no hair
Postby Matthews » Mon Dec 12, 2011 8:19 pm
Maybe the broken button was why it stopped working then !!! :shock:
Postby Rod » Mon Dec 12, 2011 9:37 pm
Its a possabilty but I was looking on the possitive side £1.50 for a battery or £60.00 for a new fob ( wish full thinking )
Postby Matthews » Tue Dec 13, 2011 5:48 pm
That's cheap try getting a new key for a Disco 2 I was told it was factory order only and full lockset £300 + :(
Bobcat
Full Name: Mark Robson
Postby Bobcat » Sun Dec 18, 2011 10:55 pm
Rod.
Did the broken button stop your hair working?? :shock:
