press
press
does anyone has a press I can borrow? Am going to re-bush the 110 with standard rubber bushes in the next month or so before next MOT. Beer token available
I've done both (rubber and poly) and as Mark said you can do it with a vice , sometimes, I've had successes and failures with both vice and press but is it worth the grief, I've also broken a vice trying to do a panhard rod bush (record vice not a cheapo one), why make life difficult for yourself. you can always sand all the rust off the inside of the holes in the arms to make it easier but by it's very nature you're making the hole bigger so the steel bush outer isn't as tight a fit as it should be, after you've struggled for a few hours , knackered a couple of bushes, bruised a few fingers and possible buggered your vice is the price difference really worth it, also once the poly's have been fitted once it's so much easier if you ever want to change them again.
Users browsing this forum: No registered users and 10 guests
