Reversing gear problem!
Picky2k
Full Name: James Pickard
Postby Picky2k » Thu Oct 20, 2011 4:03 pm
Hi chaps & chapess'
My little bro has just bought his first Discovery 1. All was going well but now it won't engage reverse gear.
Is this a well know problem? If so, is it a simple fix or is he looking at a new box?
If we get it sorted he will hopefully be trailing with us very soon.
Thanks in advance
James (& Matty)
Postby davew » Thu Oct 20, 2011 7:12 pm
Will it engage park and drive OK ?
Postby davew » Thu Oct 20, 2011 7:39 pm
Or...if it happens to be a manual box, will it go into 5th OK ?
Picky2k
Postby Picky2k » Fri Oct 21, 2011 9:04 am
Hi Dave,
She is manual and goes into 5th just fine.
Cheers...James
Postby davew » Fri Oct 21, 2011 9:38 am
I'm not aware of any common problems other than one where you can't select 5th either.
If you can't physically get the gearstick into the reverse position I'd start by checking the simple things like the reverse switch. Failing that, I believe taking the selector mechanism off the top of the gearbox is pretty straight forward and you may find it's something simple in there. Never had to do it myself on an R380 though.
Any further into the box and you're on your own :)
Picky2k
Postby Picky2k » Fri Oct 21, 2011 12:20 pm
Cheers Dave,
Problem now solved, turned out to be a rogue washer! :oops:
See you soon...James
