Novice building a wreck!
David, this is Bo on Rod's logon, from the pictures I have to say it doesn't look too bad. One thing to bear in mind is that you need to measure from the centre of the wheel hub to the body line on the wing front and rear to establish if it is sat level. Measuring to the underside of the arches is okay fro checking side to side but not back to front.
finally finished motor after 6 months and passed MOT (with a little help from Mr Sykes!) changed signature from "yeah! I dont't know what I'm doing" see the before and after pictures Thanks to everyone for all the advice given
Users browsing this forum: Google [Bot] and 344 guests
