Rod's bobtail project
Rods AA van
After John's blue trailer it'll make a change for Rod to be doing the towing.....
Rod,s Rangie
It's abit like the Loch Ness Monster, we've all heard of it, but very few have actually seen it!
The rumours coud be true as I have booked the MOT, still got a lot to do but am sure with Bo`s help ( and r lass has already said she will find some thing to do over the weekend, in other words she is going to bu--er off, every cload does not have a silver lining as that means Ill have to make the tea and butties at snap time) it will be about there.
Here are some more photos to give you a little update
To think is all start because of the MOT in the first place
May I point out the following,
"And there's also the fact that you and Bo are setting out or so I was told !
Matthew"
Fact;–noun
1. something that actually exists; reality; truth: Your fears have no basis in fact.
2. something known to exist or to have happened: Space travel is now a fact.
3. a truth known by actual experience or observation; something known to be true: Scientists gather facts about plant growth.
4. something said to be true or supposed to have happened: The facts given by the witness are highly questionable.
5. Law. Often, facts. an actual or alleged event or circumstance, as distinguished from its legal effect or consequence. Compare question of fact, question of law.
6. Neither Bo nor Rod agreed to set out this year, however if allowed to trial as well they may consider it.
Matthew"
Fact;–noun
[quote="davew"]Can I be the first smart arse to point out that with the filler tube there you won't be able to fill it ?
(quote="Bo")You have not considered a plan so cunning you could pin a tail on it and call it a fox!
It,s a FOX!
It,s a FOX!
Made it through the MOT this morning so I will be at RHB this weekend to see if it has been worth all the time and effort
Oh and Bo,s cunning plan worked with the tank
Next job is to sort the spring out so it sits a bit more level
I have added more of the pictures taken wial bobtailing the rangie these may help those who are considering doing a bobtail
Users browsing this forum: No registered users and 353 guests
