Dump Trouble
Dump Trouble
Postby varleym » Wed Feb 06, 2013 5:54 pm
No, it's not what you think.
Having a bit of trouble with my 1 ton diesel dump truck that's developed an electrical starting problem. I suspect one of the controller/relay components is duff as I'm getting intermittent and varying symptoms occuring.
It's quite old and is just used offroad (it is actually a 4x4 so it qualifies for the forum!) so I was thinking of bypassing all the existing wiring and rigging up a harness to power the fuel pump when the ignition is on and then a feed direct to the starter solenoid when you turn & hold the key at the starting position. When the ignition is switched off it would cut power to the fuel pump and thus stop the engine.
Is this logic too simple? (Useful) comments appreciated.
Postby varleym » Sun Feb 10, 2013 11:12 am
Thanks for all the helpful tips (!!!). managed to sort the wiring so it started however had a small problem of not being able to stop it even when the ignition was off :?
Finally worked out that solenoid in the injector pump is open when there's no current to it ie. let's the fuel through, and has to be energised to close it. Rigged up a circuit with a push-button I had lying around and now sorted.
Postby Matthews » Sun Feb 10, 2013 6:54 pm
Thats how you stop old motorbikes, a button on the handlebars to earth the coil
Postby Rod » Mon Feb 11, 2013 7:22 pm
i always stopped my old motor bikes by falling off,
That worked ok too
Stercus fit !
Postby repton » Tue Feb 12, 2013 3:42 pm
Rod wrote:i always stopped my old motor bikes by falling off,
That worked ok too
In my personal experience they tend to keep running when you fall off, especially if part of your body ends up near the rear wheel.
Users browsing this forum: No registered users and 19 guests
