110 springs
110 springs
It's about time I give the 110 some new springs as the current set seemed to had sagged. Question is which ones to replace them with? Not sure what it has currently, apart from being rusty, old and battered.
Due to the heavy PTO winch at front, seems logical to go for the HD front springs, NRC9448 for both side with that little lift and being levelled.
The rear is normally not loaded, so am having some thinking on the NRC6389 at 330lbs, which maybe too hard for trialing. So, could I actually fit the NRC6388 at 180lbs (meant for 110 with Boge self leveller, and mine doesn't have that)? I know they will be really soft, and will squad down at rear when carrying loads.
What other springs options will any of you suggest? And at what spring rate combination? I do not necessary need to lift the vehicle, as have no intention to fit bigger tyres. But wont mind a mild lift too.
thanks guys...!!!
red green = NRC6904...330lbs/ft...15.55" length
red red = NRC6389....330lbs/ft...16.02" length.......so going for these at the rear..
red white = NRC4304....170lbs/ft....16.95" length
blue red = NRC9448......225lbs/ft....15.31" length.....so, am going for these for the front
Cheers!!!
http://rovers.red90.ca/springinfo.html
Cheers!!!
Users browsing this forum: No registered users and 377 guests
