Any thoughts on this
http://cgi.ebay.co.uk/Landrover-90-Roll-Safety-Bar-/370443835450?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item56402c583a
I have a tiny budget so can afford a full cage etc. This may go some way to saving my hair do in a roll and I could add a bar for centre seat belts.
What do you think. Anyone got anything similar. Nick C is this like yours?
Forget the bends
If you are on a budget and no bending gear just cut and weld straight box or tube, my guestimate is 20 to 30 quid on the bare steel, if you want more strength put braces in, it will do the job but probably wont get approval for comps requiring certified cages even if its stronger because it hasnt been tested.
I've been trying to figure out how it mounts "directly behind the seats" on a truck cab. The main hoop looks from the pics as if the bottom of it sits at the same height as the rear stays. The rear stays are bolted flat to the inner wheel arches in the rear tub and then the shorter two extension pieces are used to bolt to the leading face of the rear cross member.
If the main hoop sits inside the truck cab I can't see what it would mount to at that height above the floor or how the rear stays would get out of the cab. It looks more like it would fit behind the bulkhead ?
That design at the back end is one that P&P use, might be worth a poke around their web site and see if it's one of theirs. If it is they'll probably have some pics of it fitted that might make more sense.
Have you asked him for some pics of it fitted ?
thats not like my one,
mine fits down behind the centre bulkhead with the 'feet' going to bottom of the floor just inside the wheel boxes. Under the floor is 2 large plates with mounting plates on the top that weld to the large crossmember the rear A frame attaches too.
simillar to this one
the one you posted pics of looks a bit like the safari cages.
Not sure the fellow is genuine, I mailed him as he suggested to see if he had more photos but he doesnt as he took it off before he converted to hard top. He also has a hard top for sale which he has nearly finished painting
Cant see anything similar on P&P which is a bit of a pants web site, but it is the type of thing I am looking for, simple, but may go some way to stopping your head from hurting too much. I may give them a bell sometime.
Keep your eyes open guys
Users browsing this forum: No registered users and 12 guests
